10-08-2015 01:21 PM
I am running into issues with trying to upgrade from 2.2 to 3.0 of Prime Infrastructure. I get this error message.
Initiating Application Upgrade...
ERROR : Filesystem is more than 75% full
Run 'ncs cleanup' to free up space, before attempting to run upgrade again
Aborting application upgrade ...
I have ran NCS cleanup, and that did not help the issue. I do see that i am out of space here:
Disk Source | Available Space(KB) | Used Space(KB) | % Used |
/dev/mapper/smosvg-rootvol | 3432400 | 330480 | 9 |
/dev/mapper/smosvg-varvol | 2971868 | 791012 | 21 |
/dev/mapper/smosvg-optvol | 38179676 | 160472116 | 81 |
/dev/mapper/smosvg-tmpvol | 1493304 | 373068 | 20 |
/dev/mapper/smosvg-usrvol | 5276576 | 1285868 | 20 |
/dev/mapper/smosvg-recvol | 84616 | 5664 | 6 |
/dev/mapper/smosvg-home | 84608 | 5672 | 6 |
/dev/mapper/smosvg-storeddatavol | 9238552 | 153700 | 2 |
/dev/mapper/smosvg-altrootvol | 84616 | 5664 | 6 |
/dev/mapper/smosvg-localdiskvol | 42140404 | 184408 | 0 |
/dev/sda2 | 88340 | 5690 | 6 |
/dev/sda1 | 452368 | 17876 | 4 |
tmpfs | 4362964 | 1721020 | 28 |
My question is what can I do to alleviate this?
Solved! Go to Solution.
10-09-2015 01:26 AM
hey
if it virtuel ou could follow this guide
http://blog.42.be/2013/01/increasing-diskspace-on-cisco-prime.html
i just incress the size with this guide becaus of the backup need 25% space left :)
other wise it complain
10-09-2015 01:26 AM
hey
10-12-2015 11:05 AM
Worked like a champ! Thank you
