Cisco Prime infrastructure v3 licensing for ASA
pmlam3274
Just wondering if anyone know if Cisco Prime Infrastructure support the Cisco ASA.  I was doing some research but i couldn't find the license part number (L-MGMT3x-xx) for the Cisco ASA.  Also, has anyone was able to use the Cisco CCW website (www.cisco.com/go/ccw) to obtains an estimate cost for the Cisco Prime infra?
Marvin Rhoads
pmlam3274
Good point - while the ASA is supported (with a few caveats), there's no part number to add licenses for it as a device on a new PI 3.x deployment.
I'd recommend you reach out via email to ask-primeinstastructure@cisco.com via email to address this question.
Hi, have you figured out which license do you need for ASA?
I found out the info about ASA licensing in PI 3.
Cisco® wireless LAN controllers (WLCs), autonomous access points, ASAs and third-party devices are not counted against the license count.
Hello Jernej,
I'm still searching this information about licensing/no licensing for ASA models in PI 3.x in all documents and couldn't find it. Can you please send me a link whre I got this information?
Thanks in advance
Andreas
