Cisco Prime Infrastructure Vritual domain issue
james.madden
Beginner
Beginner
Hi All,
I'm having issues with Prime Infrastructure whereby I created a few Virtual domains and linked the devices to these virtual domains now I want to edit the existing domains to add/remove devices,
When I select the Domain on the left hand side it should populate the right hand side with the associated devices, it just stays blank,
Noted for the documentation Cisco mentions it can take several minutes, we only have 800 devices loaded and brought a lic for 1500
Any help would be appreciated
James
4 REPLIES 4
predrag2006
Beginner
Beginner
I had a similar problem, resolved by reboot.
Predrag Petrovic
Thanks for the feedback,
After reboot issue is still present,
Would anyone recommend installing 1.3?
I am running 1.3, I was running 1.2 for two days only until I faced issues with WCS and Autonomous Access Points.
Predrag Petrovic
ALEXIS N. FLORES
Beginner
Beginner
I´m having same problem, but we are working with 2.1 (2.1.0.0.87) version.
I can create new domain, but the TABs never shows any component, no matter which TAB I chosse.
Have do you solved this problem ?
Alexis
