CISCO PRIME INFRASTRUCTURE
clarkem73
Need help on how to discover the devices in cisco prime ..? what are the confirgurations needed in the switch, controllers
Did the following but still get the devices as unmanaged in Cisco Prime Infrastructure
username CISCO privilege 15 secret cisco@123line vty 0 4
login local
snmp-server community Myview10 RW
snmp-server community public RO
snmp-server contact  IT_DEPART
snmp-server host 192.168.0.1 version 2c MMyview10
Does anyone have a working template for bulk device adding?
Marvin Rhoads
The config looks basically adequate.
When you add a single device via the GUI, Verify credentials prior to adding. What result do you get?
The devices still shows as unmanaged-
Error occurred due to invalid SNMP credential
Sooooo - fix the SNMP credential.
Most likely causes are
1. The RO or RW is incorrect in PI or
2. There's an ACL on the switch or somewhere in between.
