04-04-2022 08:58 AM - edited 04-04-2022 08:59 AM
I am new to Cisco Prime.
I want to know how to install Cisco PI without ESXI as customer is not having the license of Esxi.
Solved! Go to Solution.
04-04-2022 10:18 AM
you can use free version :
https://www.vmware.com/uk/products/vsphere-hypervisor.html
If not PI can not install directly on to hardware, rather customer need to buy appliance.
04-04-2022 10:47 AM
04-04-2022 09:07 AM
Alright, but then, which other virtualization system you have?
The other option you have is buy an appliance.
04-04-2022 09:44 AM - edited 04-04-2022 09:53 AM
Appliances comes with pre-installed PI or we have to do something in that??
They are using UCS server c220 M4 and is fresh installation, with no virtualization system. Is there any way to deploy .iso file in KVM.
04-04-2022 10:11 AM
Yes, Appliance comes with pre-deployed PI and yes, it is possible to install in KVM with ISO.
04-04-2022 10:35 AM
Can you please share any link or procedure for this deployment, because not getting full documents on this for KVM ISO installation.. I have tried to install with ISO file but it is installing Red Hat Linux.
04-04-2022 10:47 AM
04-04-2022 10:18 AM
04-04-2022 06:59 PM - edited 04-04-2022 07:01 PM
Means I cannot Install iso file directly to UCS server.. I will need Esxi for the same..
Vmware provides Free version for how many days? Because in this link it is mentioned that Use Vsphere free for 60 days...
04-06-2022 08:40 AM
Short answer NO, you can not install on baremetal (i guess) - if that is possible why Cisco selll their prebuild appliance.
