cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Cisco Prime Infrastucture 3.7 error 500 Users
Hola a todos
Se ha presentado error 500 al listar los Usuarios en Cisco Prime Infraestructure  3.7.0 Built 3.7.0.0.159
El error se genera a partir de tratar de eliminar un usuario admin, y al buscarlo en los grupos asignados aún se evidencia.
Anexo captura del error.
5 RESPUESTAS 5
balaji.bandi
Try to reload Prime and test it.
BB
Hi, balaji.bandi
We already did the restart of PI, then the ncs stop process was stopped and restarted with the ncs start command and even so I cannot list or create a user continues with error 500
is this High availability or single PI ?
post below output :
show application status.
check the disk space :
https://www.cisco.com/c/en/us/support/docs/cloud-systems-management/prime-infrastructure/200720-Prime-Infrastructure-Troubleshooting-L.html
BB
this is single PI
check my suggestions and post the outcome where required for us to understand the issue.
BB
