Cisco Prime NAM 5.1
dverasteguin
Hi!!
I have a question!!
I want to build a small demo with the new Cisco Prime NAM 5.1; however, I only have a NM-NAM module for a Cisco Router 2811.
I've read the data sheets and I've come across info that the NAM 5.1 software can be installed on the NME-NAM module which is the replacement for the previous one. Nevertheless, it doesnt say that its not supported on the NM-NAM.
Therefore, my question is, can I install the NAM 5.1 image on a NM-NAM module??
Please I would appriciate your repply. ASAP, the Networkers is coming up and we are deploying a NAM demo!
Thank you very much!!
Sincerely,
Dante Verastegui
AFROJ AHMAD
Hi Dante,
Unfortunately NM-NAM Module is NOT the supported Upgardes for NAM PRIME.
Here is the supported list :
http://www.cisco.com/en/US/customer/docs/net_mgmt/network_analysis_module_software/5.1/release/notes/nam51note.html#wp49466
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi Dante,
Afroj
Afroj,
Thank you for your repply.
Ill try to set it up in a SRE module.
Sincerely,
Dante Verastegui
Alfroj,
I downloaded the NAM 5.1 software to be installed on a SRE Module.
I was wondering if you could help me out with an error.
When i configure the module and then try to install the files from a ftp server, it doesnt work.
It loads all the files and when its installing, theres a crash and the system reboots. It does this all the time. Just keeps rebooting and rebooting.
Im attaching the messages I get
I would appriciate if you could help me out
Thanks in advance
Sincerely,
Dante Verastegui
