Cisco Prime NCS 1.2.1.012 nms stopped
Ben Cass
Hi all,
Got an issue with nms server stopped, it is the full 3300 appliance not a vm, have tried:
1.
ncs stop
ncs cleanup
ncs start
2.
ncs stop
ncs redidb ( off the top of my head can't remember exact command for that one)
ncs start
3.
tried reboot after ncs stop
Getting this ouptu on ncs start:
As first time is not present - removing .dbCreated
Starting Network Control System...
Unable to verify hardware.
This may take a few minutes...
Also on ncs start verbose getting a massive error:
Processing Service Name: NMS Server
Remoting 'Matlab Server' started successfully.
Starting NMS Server
Checking for running servers.
  Checking if DECAP is running.
  00:00 DECAP is not running.
00:00 Check complete. No servers running.
  00:11 DECAP setup complete.
  Creating the DB schema
Removing configuration folder on DB clean
DDL execution of the script /opt/CSCOlumos/bin/aems_ddl.sql failed. Please check the log file /opt/CSCOlumos/logs/ddl_log.log. Exiting XMP startup.
DDL execution of the script /opt/CSCOlumos/bin/compliance_engine_schema.sql failed. Please check the log file /opt/CSCOlumos/logs/ddl_log.log. Exiting XMP star
tup.
MP startup.
DDL execution of the script /opt/CSCOlumos/bin/cr_proc_drop_part.sql failed. Please check the log file /opt/CSCOlumos/logs/ddl_log.log. Exiting XMP startup.
tup.
DDL execution of the script /opt/CSCOlumos/bin/disableStats.sql failed. Please check the log file /opt/CSCOlumos/logs/ddl_log.log. Exiting XMP startup.
DDL execution of the script /opt/CSCOlumos/bin/ifm_ca_exclude_list.sql failed. Please check the log file /opt/CSCOlumos/logs/ddl_log.log. Exiting XMP startup.
artup.
DDL execution of the script /opt/CSCOlumos/bin/ifm_ca_mainpage_view.sql failed. Please check the log file /opt/CSCOlumos/logs/ddl_log.log. Exiting XMP startup.
tartup.
DDL execution of the script /opt/CSCOlumos/bin/ifm_indexes.sql failed. Please check the log file /opt/CSCOlumos/logs/ddl_log.log. Exiting XMP startup.
DDL execution of the script /opt/CSCOlumos/bin/ifm_sam_foundation_system_ddl.sql failed. Please check the log file /opt/CSCOlumos/logs/ddl_log.log. Exiting XMP
startup.
ing XMP startup.
DDL execution of the script /opt/CSCOlumos/bin/ifm_sam_ipsla_ddl.sql failed. Please check the log file /opt/CSCOlumos/logs/ddl_log.log. Exiting XMP startup.
tup.
DDL execution of the script /opt/CSCOlumos/bin/ifm_sam_ipsla_default_data.sql failed. Please check the log file /opt/CSCOlumos/logs/ddl_log.log. Exiting XMP st
artup.
XMP startup.
DDL execution of the script /opt/CSCOlumos/bin/ifm_sam_pm_ddl.sql failed. Please check the log file /opt/CSCOlumos/logs/ddl_log.log. Exiting XMP startup.
DDL execution of the script /opt/CSCOlumos/bin/ifm_sam_pm_lt_ddl.sql failed. Please check the log file /opt/CSCOlumos/logs/ddl_log.log. Exiting XMP startup.
tup.
DDL execution of the script /opt/CSCOlumos/bin/ifm_sam_pm_lt_sp.sql failed. Please check the log file /opt/CSCOlumos/logs/ddl_log.log. Exiting XMP startup.
up.
DDL execution of the script /opt/CSCOlumos/bin/ifm_sam_pm_mt_ddl.sql failed. Please check the log file /opt/CSCOlumos/logs/ddl_log.log. Exiting XMP startup.
tup.
DDL execution of the script /opt/CSCOlumos/bin/ifm_sam_syslog_ddl.sql failed. Please check the log file /opt/CSCOlumos/logs/ddl_log.log. Exiting XMP startup.
rtup.
DDL execution of the script /opt/CSCOlumos/bin/ifm_sam_system_ddl.sql failed. Please check the log file /opt/CSCOlumos/logs/ddl_log.log. Exiting XMP startup.
rtup.
DDL execution of the script /opt/CSCOlumos/bin/ifm_swim_default_repo.sql failed. Please check the log file /opt/CSCOlumos/logs/ddl_log.log. Exiting XMP startup
startup.
DDL execution of the script /opt/CSCOlumos/bin/job_schema_update.sql failed. Please check the log file /opt/CSCOlumos/logs/ddl_log.log. Exiting XMP startup.
tup.
DDL execution of the script /opt/CSCOlumos/bin/ncs_api.sql failed. Please check the log file /opt/CSCOlumos/logs/ddl_log.log. Exiting XMP startup.
DDL execution of the script /opt/CSCOlumos/bin/wcs_dropFKs.sql failed. Please check the log file /opt/CSCOlumos/logs/ddl_log.log. Exiting XMP startup.
DDL execution of the script /opt/CSCOlumos/bin/wcsutils.sql failed. Please check the log file /opt/CSCOlumos/logs/ddl_log.log. Exiting XMP startup.
DDL execution of the script /opt/CSCOlumos/bin/wda_ddl.sql failed. Please check the log file /opt/CSCOlumos/logs/ddl_log.log. Exiting XMP startup.
DDL execution of the script /opt/CSCOlumos/bin/wirelessAlarmSpecificId.sql failed. Please check the log file /opt/CSCOlumos/logs/ddl_log.log. Exiting XMP start
up.
P startup.
DDL execution of the script /opt/CSCOlumos/bin/xmp_credential_mgr_ddl.sql failed. Please check the log file /opt/CSCOlumos/logs/ddl_log.log. Exiting XMP startu
p.
startup.
DDL execution of the script /opt/CSCOlumos/bin/xmp_fingerprints_ddl.sql failed. Please check the log file /opt/CSCOlumos/logs/ddl_log.log. Exiting XMP startup.
tartup.
DDL execution of the script /opt/CSCOlumos/bin/xmp_preference_ddl.sql failed. Please check the log file /opt/CSCOlumos/logs/ddl_log.log. Exiting XMP startup.
rtup.
DDL execution of the script /opt/CSCOlumos/bin/xmp_quartz_ddl.sql failed. Please check the log file /opt/CSCOlumos/logs/ddl_log.log. Exiting XMP startup.
DDL execution of the script /opt/CSCOlumos/bin/xmp_rbac_ddl.sql failed. Please check the log file /opt/CSCOlumos/logs/ddl_log.log. Exiting XMP startup.
DDL execution of the script /opt/CSCOlumos/bin/xmp_usermgmt_ddl.sql failed. Please check the log file /opt/CSCOlumos/logs/ddl_log.log. Exiting XMP startup.
up.
Any ideas ?
Hi Ben:
There are .iso images for both Prime Infrastructure 1.2.1 and the current release, Prime Infrastructure 1.3.0.20 that can be downloaded and burned to a Dual Layer DVD (in a Dual Layer DVD burner) and used to reimage the physical appliance with.  These physical appliances shipped from a factory with a hard drive that has magnetic  representations of 0 and 1 on it, it's entirely possible something  happened to something to the data in transit.  Reimaging puts everything back to square one and completely rules out the  possibility of anything being corrupted.
Once it's running again, be sure to check out and install the Update 1 patch for Prime Infrastructure 1.3.0.20 (filename PI_1.3.0.20_Update_1-12.tar.gz).
Release Notes for Update 1 for Cisco Prime Infrastructure 1.3.0.20
Rollin Kibbe
Hi Ben:
The message "As first time is not present - removing .dbCreated" indicates that the Oracle onboard is not able to find a recognizable database, and thinks it's supposed to kick off the scripts that create an empty one, and populate it with the necessary tables to run Prime Infrastructure.  This message is usually seen either a) on a new installation, or b) after someone purposefully reinitializes the database.
Be prepared to restore from a backup.  Depending on what your step 2. involved, you may have a catastrophic situation on your hands.
Thought it might require a recovery, its a brand new appliance so no configuration has been implemented, just setup wizard was completed. It occurred on the first boot of the appliance, does NCS come pre installed or would a disti install the software on the appliance ?
Haven't actually checked if there is a backup, not sure there would be if its out of the box.
Thanks for the response.
Hi Ben:
