Cisco Prime NCS Install
Ben Skinner
I am trying to play around with NCS.
I have ESXi box (4.1 and 5) and have tried using both ver 1.0 and 1.1 of the appliance.
The error i get on boot up is
Failure during Network Control System startup. Check launchout.log for details
How can i check that logfie?
18 Replies 18
I have same error.
Failure during Network Control System startup.  Check launchout.log for details.
Dear,
follows this procedure to be performed. I tested it and it worked.
1.> Please try these commands then try to start
the ncs:
ncs stop ( 3 times)
reload.
ncs status ( email me the o/p)
2.> If the #1 does not helps  please run
ncs cleanup
3> Note: If the above does not help, and only if *** this is new install ***, it might
be ok to re-init the DB ( use your own judgement )
Note: NCS DB you will loose previous data when you re-init. but if this DB corrupt issue
may help.
the ncs:
ncs stop
ncs db reinitdb
ncs start
Hugs.
Craig Le-Butt
Did you problem heve get sorted?  I'm having the same issue, looked at launchlog, which says check startup.log which seems to be da."startup.log"
I've found some errors, but can't find anywhere to check these against.
anyone have any ideas, don't realy want to reonotdb.
cheers
relder
Just happened to me.  I am running version 1.3.0.20.
I already did a NCS CLEANUP, and it finished sucesfully, but unable to start it.  It looks like I have enough space..
I have 30,293,413,888 byes available.  So i don't think it is a disk space issue.  The device was working good till today.
Thanks!
Edit - I did reboot it as well.  Nothing.
