Cisco Prime Network Control System (NCS) problem
aameur.ym
Beginner
Beginner
Hi all,
I want to reach out with my problem
I have a Cisco Prime NCS physical appliance, and I have the HDD problem decribed in the field notice below and I need to know if the described workaround is permanent or I should replace the HDD occasionally
https://www.cisco.com/c/en/us/support/docs/field-notices/636/fn63645.html
Thanks in advance
Mehdi
marce1000
VIP Mentor VIP Mentor
VIP Mentor
 - The idea is that if your device is affected, then the replacement  disks should work, permanent.
M.
-- ' A nun once asked a penguin ' do you think the earth is flat ? ; the penguin replied :
Madam, it all depends , in Riemann geometries the earth can be perfectly flat! The nun thanked him , he tripped and fell forward : the poor animal had forgotten that he might be living in a Riemann geometry too!
marce1000
VIP Mentor
M.
Recognize Your Peers
