Cisco Prime + SNMP + WLC
Jay_F
i've managed to get most of my WLCs into cCsco Prime, bar 1x. This one has been incredibly awkward and will not accept my SNMPv3 credentials - the exact same procedure worked for all my other WLC's. I set the AuthMode to HMAC-SHA & Privacy Type to CFB-AES-128 on both the WLC and Prime. Using Prime Infrastructure 3.2 device pack 4. Whenever I try to verify my credentials from the prime box i get: "Device unreachable for SNMP V3 credntials"- credentials entered are correct and the device is reachable from prime to wlc and wlc to prime. What could be wrong? possibly a bug ? I updated Prime to the latest. Has anyone experienced this issue before that could possibly help?
10 Replies 10
marce1000
 - Does the controller have snmpv3 enabled in it's snmp settings ?
M.
-- ' 'Good body every evening' ' this sentence was once spotted on a logo at the entrance of a Weight Watchers Club !
Yes it does. Confirmed from GUI and CLI.
 - Ok, you could , for instance, verify your snmpv3 configuation , with other tools besides cisco-prime ; google on 'snmpv3 test tool'  or 'free snmp manager software' ; the latter could be used for mib-browsing on the controller over snmv3 (e.g.)
M.
Thanks I tried and got the following error:
No response (check: firewalls, routing, snmp settings of device, IPs, SNMP version, community, passwords etc) (SNMP error # -2003) ( 0 seconds )
Odd that i can ping the controller IP and the controller is local and both prime & wlc are on the same subnet, no firewalls in the way. Beginning to think this could be a bug of some sorts with the controller.
Any ideas?
 - What do you mean by error 2003 ; where does this come from (which app) ?
M.
It came from the app you suggested called Paessler SNMP Tester
 - Begins to sound as a bug; check your current  controller version, versus requirements linked to prime version installed (google on stuff as 'wireless compatibility matrix' and or 'cisco prime compatibility matrix'). Possibly try a next version on your controller, but stay compatible with Prime.
M.
ok thanks for your help marce1000. I think we will look into upgrading the firmware of this particular WLC as i suspect some type of bug.
Facing similar situation, has it been resolved after upgrading?
We have 3 wlcs and I can successfully add 2 Wlcs into prime. The other one has issue. Just that the first 2 wlcs are in the same network as of the prime whereas the last one is not. However I have checked the connectivity and I am able to ping the wlc from the prime.
What model WLC is it ? and what version of firmware does it have ? This was some time back for me but I remember it was affecting our anchor controller. We ended up upgrading the firmware which resolved the problem.
