Cisco Prime Topology Map not auto-discovering all links vers 3.10
We are running Cisco Prime 3.10 and trying to make use of the topology maps.
It has never worked like it should from version 3.3-3.10 Never tryed before 3.3.
Some links between switches are automatically showing but not all. CDP is running on all of them and if I run show cdp neighbours on the switches the links are definitely in there.
If I go to the '360 view' for one of the units, all the links are there.
Does anyone one know how to:
1. Execute the SQL commands to clean the Link related tables
Thx
Brian
0 Replies 0
