Cisco Prime UPMDbMonitor and UPMProcess shutdown
aparada14
I have a Cisco Prime LMS 4.1 in soft appliance, all process are running in normal state and suddenly
UPMDbMonitor and UPMProcess are in a Administrator has shut down this server state. Why is this happen?
I start again these two processes and stay in normal state, but some time later they come down (Administrator has shut down this server)
ngoldwat
Level 4
Level 4
It could be that you are in ACS mode and the System Identity user is not having the required privileges for running LMS tasks.
I have configured LMS server in Current Login Mode: CiscoWorks Local. When I see the processes down I issue the command:
pdexec UPMDbMonitor  UPMProcess
I start them up and stay in running normally status for few hours, but I haven´t found why this is happening.
Regards.
Vlad Vlaicu
Could you share UPMDbMonitor.log and UPMProcess.log found in the logs folder of your LMS installation?
Vlad
========== NMS Team Krakow, Poland Cisco TAC
Enclosed you will find both files requested. I have been checking the behavior of the processes and viewing some features about LMS and something else is affected for these processes, I have an error in My Menu > Monitoring showing Sybase Odbc Driver Sql Anywhere Communication Error in Interface Availability, Top N interface utilization, Top N Interface Errors and Top N interface Discards.
Regards.
