Cisco Prime UTC/GMT Lobby Ambassador Issue
thomas03usmcsf
Level 3
Level 3
After creating guest user credentials via Cisco Prime Lobby Ambassador, you receive a summary page(attached) that list the start time and end time.  The issue is that the times show up in UTC instead of GMT, does anyone know how to change this?  Thanks.
AFROJ AHMAD
If you are running an old version( PI 1.2  )   then you might be hitting this BUG:
Guest account is not working according to its Time Zone.
CSCuj09430
Thanks-
Afroz
***Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Thanks for the reply, but it is Prime 2.1
I am not  sure ,if this BUG is applicable to P1 2.1 or not , hopefully not .but you can contact TAC  to confirm the behavior.
If  anyone have a different view ,kindly share it with us.
Thanks-
Afroz
