164
Beginner
Cisco prime
Can any one help out,
How do  I check the attempts that have been made to authenticate on there SSIDs ?
3 REPLIES 3
VIP Advisor
Re: Cisco prime
You can do from reports select SSID, or from Controller you can get report.
BB
*** Rate All Helpful Responses ***
Beginner
Re: Cisco prime
i have tried in reports but nothing can u giv more detail or example
Highlighted
Beginner
Re: Cisco prime
hi
how do i do the following?
1- view current profile applied to a specific floor in terms if ssid using cisco prime
2- the current confuration on AP/Cintroller
thanks
shakil
Content for Community-Ad
July's Community Spotlight Awards
