01-21-2015 10:40 AM
Hi Experts,
we are using prime 2.1 in our network.
And we have around 2100 devices(routers,switches,ASA,WLC's) in the prime.
We are facing server slowness while accessing the Prime Device.
TD.
01-21-2015 12:54 PM
Experienced the same issues while on 2.1 (recently upgraded to 2.2 and haven't used enough to say the problem is gone). We have Prime deployed as a virtual appliance with the standard build. At times it would become completely unusable and the only fix was restarting the services.
01-21-2015 04:00 PM
What's you platform? If it's a VM have you checked out the guest performance in Vcenter? That gives you good insight into which resource is most constrained (CPU, memory, disk I/O, etc.).
Is the installed image the one recommended for the tier of use you are actively using? Even if so, in a VM environment you can allocate additional memory or cores to speed things up.
Other things to look for include excessive syslog message rate and lots Netflow records/second (if you're using Assurance).
