Cisco router 8803G telnet commands
kouliscon
Hello all
i have a Cisco Router 8803G and i would like some help with following commands to be runned by telnet:
1) erase an admin user
2) change the passwork of an admin user
thx in advance
you can see a list of users with the following command:
sh run | include username
Go to config mode and do a
no username USER_YOU_WANT_TO_DELETE
The password can be changed with the same command
username USER_YOU_WANT_TO_CHANGE secret NEWPASSWORD
or in case you don't use hashed passwords:
username USER_YOU_WANT_TO_CHANGE password NEWPASSWORD
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
thx a lot for the answer
