ā06-18-2020 07:15 AM
Hi i have a IPSec tunnel between cisco router and fortigate the ipsec working perfectly but in fortigate side the peer id name is not showing and i have multiple sites so i cant surpervise so is there any configuration on the router to give him a peer id or something please help me
Solved! Go to Solution.
ā06-21-2020 07:05 AM
ā06-18-2020 07:57 AM
HI,
IKEv1 use "crypto isakmp identity address/dn/hostname" or "self-identity" command under ISAKMP profile
or
IKEv2 you configure "identity local address/dn/e-mail/fqdn" under your IKEv2 profile.
ā06-21-2020 01:08 AM
hi thank you for your reply but still not showing the peer id is empty
