Beginner
cisco switch
hello all
what the best and easy way to delete cisco switch running configuration or return it to manufacture setting ?
thanks
2 ACCEPTED SOLUTIONS
Highlighted
Beginner
Re: cisco switch
You can use "erase startup-config"  and then "reload"
Collaborator
Re: cisco switch
This will depend on the type of switch you have. On the ios switch you will need to delete flash:/config.text and flash:/vlan.dat
John
**Please rate posts you find helpful**
3 REPLIES 3
Highlighted
Beginner
Re: cisco switch
Beginner
Re: cisco switch
i did
thanks
i delete the switch flash by mistake , do you know how to get it back ?
Collaborator
Re: cisco switch
John
Content for Community-Ad
