cisco switch
ghaith_gld
hello all
what the best and easy way to delete cisco switch running configuration or return it to manufacture setting ?
thanks
2 Accepted Solutions
Abdul Farooq
You can use "erase startup-config"  and then "reload"
johnd2310
Level 8
Level 8
This will depend on the type of switch you have. On the ios switch you will need to delete flash:/config.text and flash:/vlan.dat
John
**Please rate posts you find helpful**
Abdul Farooq
i did
thanks
i delete the switch flash by mistake , do you know how to get it back ?
johnd2310
Level 8
Level 8
John
