CISCO SX550X SNMP problem
Kuk93
I'm currently working on a CISCO SX550X and I've encountered some problems when using SNMP for getting the values of some parameters.
For example im asking the device for cpmCPUTotal5sec at OID .1.3.6.1.4.1.9.9.109.1.1.1.1.3
Then I try to execute :
root:  snmpget -v2c -c public (IP adress) .1.3.6.1.4.1.9.9.109.1.1.1.1.3
I get :
root: enterprises.9.9.109.1.1.1.1.3 = No Such Object available on this agent at this OID
Can you tell me where is the problem?
5 Replies 5
marce1000
 - Try snmp-walking a somewhat shortened version of the OID (cut some numbers at the end). Some times the OID's are slightly different.
 M.
The same problem...
root:  snmpwalk -v2c -c public (IP adress) .1.3.6.1.4.1.9.9.109
root: :enterprises.9.9.109 = No Such Object available on this agent at this OID
 - Use the latest firmware , if not yet done, note that these small business devices may not implement all the MIBS being available on IOS-based devices.
 M.
I have the lastest firmware. Where can I find whether such parameters are available on this device?
 - Look if the particular MIB is available from the MIBS supported by the device :
           https://software.cisco.com/download/home/286305599/type/283415684/release/2.5.5.47
 M.
