nhkelley1
Beginner
CISCO UCS 5100 CHASSIS (FSM FAULT F999448)
Here are the details of the critical error:
Cisco UCS 5108 Chassis: Serial # ............ Sys/chassis-2/locator-led
Description: [FSM:FAILED]: set locator led to inactive (FSM:sam:dme:EquipmentLocatorLedSetLocatorLed).
Remote-Invocation-Error:
Cause: fsm-failed
Code: 999448
Severity: critical
The Chassis equipment (blade servers, LED locator light, IO modules, and power supplies) are fully operational.
Any suggestions?
Thank you.
3 REPLIES 3
marce1000
VIP Advisor
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/ts/faults/reference/ErrMess/UCS_FSMs.html
   - Lookup the particular fault code in this document using find in your browser
M.
Thank you for your response Marce1000
The FSM Fault Code is F999448.
v/r;
Ned
riaan.vanniekerk
Beginner
If yours is the same issue, according to
Critical fault on FSM when Chassis Locator LED set
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCux19514
Workaround:
Toggle the LED On and then Off.
If toggling the LED does not clear fault, reset the IOM connected to the current subordinate Fabric Interconnect in the affected Chassis and toggle the LED which should clear the fault.
Or upgrade to 2.2(7b) or newer
