07-14-2005 01:34 AM
Hi i would like to check with you guys with anyone knows if there are any cisco works 2000 user manual for sale or does it actually comes with the cds? i dont seems to be able to find it on cisco press web site. Could someone please advice? Thanks a lot in advance
Solved! Go to Solution.
07-14-2005 01:54 AM
There's a book called "Cisco Enterprise Management Solutions: v. 1" which is quite useful. It's going to be a bit dated by now (not so good if you are running the latest version i.e. LMs 2.5), and it's focused mainly on RME, however, it has some good info on CiscoWorks as a whole and it's mechanics
They never followed up with vol 2 etc which were supposed to cover the other CiscoWorks modules in more detail - That's a bit of a shame really :(
You can get this book through the following link:
Additionally, you can download all the User Guides in .pdf format through:
http://www.cisco.com/en/US/products/sw/cscowork/ps2425/tsd_products_support_series_home.html
Hope this helps
Marcus Jones
07-14-2005 01:54 AM
Hope this helps
Marcus Jones
