Cisco Works ANI server
shansuresh
According to the Process status, ANI server is started, BUT when you click to analyze ANI server, we get the following error:
AniWrapper>>analyze(SYSTEM) Server Named: ANIServer4.2-alfcwXXX on port: 14004
Nothing has been done on that server.
When i try to modify the SNMP settings, I get the following error:
"The ANI Server is not responding. Verify that the ANI Server is up and running".
Please help, as I dont want to rebuild the server.
umedryk
Level 5
Level 5
Stop the daemon manager: net stop crmdmgtd
Remove existing servlets cd to the CiscoWorks directory cd
lib\jrun\jsm-cw2000\services\jse\servlets Delete everything in here (dirs and files)
Restart the daemon manager net start crmdmgtd
Go to the control pannel of the client workstation that you are using, and open the java plug-in,
select the cache tab and click on "clear JAR cache".
