Cisco works backup ASA configuration along with visible PRE-SHARED KEY (PSK)
mmali
We are taking configuration back of ASA firewalls using Cisco works LMS
Everything works fine. Here is what we are trying to achieve
We would like to have the PRE-SHARED KEY (PSK) from the ASA configuration to be decrypted while Cisco works is taking automated backup.
For example: as of today when Cisco works takes any configuration backup, the PSK is encrypted.
Is it possible to add this command ( “more system:running-config”) in below cwcli command
cwcli config get -u userid -p password [-d debuglevel] [-m email] [-l logfile][-timeout seconds] [-filetype running|startup|runningstartup] { -device list | -view name | -device list -view name |-ipaddress list }
cwcli netshow createjob -u Username -p Password -customcmd " more system:running-config " -schedule Schedule -scheduletype Schedule Type
Cisco works LMS
Cisco ASA 5505, 5510 Version 8.2, ASDM version 6.2
Mudassir
Gaganjeet Chug
Level 4
Level 4
Actually No, Its not possible to have the PRE-SHARED KEY (PSK) from the ASA configuration to be decrypted while Cisco works is taking automated backup. This could be because of the security issues not to have the password in clear text.
But, Bug for this issue have been already filed to track down this issue. BUG ID =CSCto14724
You can view this bug at the below URL :-
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?caller=pluginredirector&method=fetchBugDetails&bugId=CSCto14724
Gaganjeet
If this post answers your question, please click the "Correct Answer" button"
