05-11-2010 01:09 AM
Hi fellows,
I've been trying to start the ANIServer process manually, also rebooted the CW server couple of times, but the ANIServer process wouldn't start.
This issue started 3 days ago and I'm sure no settings have been changed on the server.
Any thoughts would be much appreciated.
Many thanks,
Moath,
05-11-2010 07:00 AM
Post your NMSROOT\CSCOpx\campus\etc\cwsi\ANIServer.properties, NMSROOT\CSCOpx\campus\etc\cwsi\ANIServer.properties.orig file along with your full LMS installation path (NMSROOT) and the output of "hostname" from DOS.
05-11-2010 08:09 AM
Typo from my part, location of files would be NMSROOT\campus\etc\cwsi\. NMSROOT would stand for your LMS default installation path which by default is C:\Program Files\CSCOpx.
05-12-2010 12:39 AM
Many thanks for your reply Joel. I've upgraded to LMS 3.2 and it worked like charm. Hope this newer version fixes the issues which existed in 3.1.
05-12-2010 09:54 AM
Well, that works too . Your ANIServer.properties was probably corrupted. When this happens you can restore from the .orig after some minor changes. Corrupted files is a common issue on Windows platforms mostly, and can occurr due to full disk drive, unclean shutdown of processes, power outage, anti-virus scanning among others. Basically, follow these guidelines which can also apply during an upgrade.
