mbroger
Beginner
Cisco Works LMS 4.x NetShow Jobs URL
I have upgraded our LMS 3.x to the new LMS 4.x Version.
I have installed the new 4.x on an new server and importet the backup.
I have importet a Certificate and have enabled the Browser-Server Security Mode:               Enabled
I added some new Netshow Jobs which run every day.
I get the email from the jobs and the URL in the email but:
http://servername:1741/rme/NSViewJobResults.do?jobId=5528.5
When i click on the link i only get:
Forbidden
You don't have permission to access /rme/NSViewJobResults.do on this server.
Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.
i must change the link to
https://servername/rme/NSViewJobResults.do?jobId=5528.5
Than it works.
Is there anywhere an option to edit the text which is send with the jobs, to fix the url?
Kind regards, Feichti
4 REPLIES 4
Gaganjeet Chug
Enthusiast
Since you have enabled the option of Browser Server security mode : Enabled, try the access the URL with the https with the port 443 like below :-
https://servername:443/rme/NSViewJobResults.do?jobId=5528.5
And see if this works.
Gaganjeet
yes thats right, but the url in the email is not right. So i must change everytime i get an email with an url the link.
I want that the link in the email is right, like yours or like mine.
Hi.
Kindly disable the browser security option and also runthe following command on the server CLI :-
CSCOpx\MDC\Apache>perl ConfigSSL.pl -disable.
and then restart the daemon manager to fix the issue.
Gaganjeet
Is the above workaround help to get this issue fixed. Kindly update.
Gaganjeet
