Cisco Works - SNMP for Pushing instead of TFTP
mshipley_2
Is there a setting in Cisco Works I can change for getting SNMP used instead of TFTP for pushing configuration changes?  I recently did a push to over
4500 network devices (routers & switches) in my network and found that Cisco Works was using TFTP instead of SNMP.  Is there a setting I can change
for getting SNMP used instead of TFTP?
Also when I look at running config on the devices, they do NOT show the name of the "profile (TACACS Account)" used to log into the device by Cisco Works.  Thus the Audit function could not pickup the profile that made the changes.
Currenting using LMS 3.2.
Joe Clarke
LMS uses TFTP triggered by SNMP.  There is no way to use SNMP exclusively to push config changes.  LMS will use one of either SNMP/TFTP, SSH, telnet, or RCP.  This is set under RME > Admin > Config Mgmt > Transport Settings.
If you are not using telnet or SSH to do config management (i.e. archive, Netconfig, etc.), then the running config will not relfect a username logging into LMS to make config changes.
