Beginner
CiscoEnvMonSupplyState MIB Incorrect reporting failure
Using SNMP ( various NM's )  the status of a PSU's in a 6509 running 12.2(33)SXH3a returns " 6:Not functioning instead of 1:Normal "
CiscoEnvMonState
1:normal
2:warning
3:critical
4:shutdown
5:notPresent
6:notFunctioning
However the PSU are operating normally and ' show env ' reports OK ...?
Has anyone else seen this issue ?
Everyone's tags (3)
3 REPLIES 3
Highlighted
Hall of Fame Cisco Employee
Re: CiscoEnvMonSupplyState MIB Incorrect reporting failure
Is this switch in a VSS configuration?  You may be seeing CSCso57334 which is fixed in SXI.
Highlighted
Beginner
Yes it is , quite possibly it's the problem - thanks
Highlighted
It certainly could be:
Symptom:
SNMP: ciscoEnvMonSupplyState and ciscoEnvMonFanStatusEntry return wrong value in VSS  setup after removing PS
Conditions:
Removal of a Power Supply (PS); only affecting VSS setup, not standalone.
Workaround:
Once plugged back a working PS, SNMP values are back to correct ones.
It's fixed in 12.2(33)SXI.
Content for Community-Ad
July's Community Spotlight Awards
