03-19-2010 01:45 PM
There are two Ten Gig interfacaces on each VS-720-10G on each chassis of a VSS 6509.
Only one of them on each chassis, the port 5, is being shown.
See the details on the attached file.
All CiscoView packages are update as today.
03-19-2010 03:09 PM
Nothing is attached, but it sounds like you may have found a new bug. II see one other SR open reporting the same type of problem, but there is currently no resolution. I recommend you open a service request so your problem can be analyzed and tracked.
03-22-2010 07:48 AM
Thanks. I dont know why, but I was getting error when uploading a .doc or .docx file.
Then converted it to .pdf and it was uploaded.
I will follow your advice and open a SR for this problem.
