Ciscoview Package File for Nexus 7010
kbyrd
Level 2
Level 2
I found an old support modules table at
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_ciscoview/device_support/table/cvsdt.html
dated Feb 28, 2012. I cannot find one newer.
I have LMS 4.1 and I'm trying to render a Nexus 7010 in Ciscoview. I have downloaded the latest package files. The Sup2 and Fab2 modules (N7K-SUP2 and N7K-C7010-FAB-2) show as "unsupported card".
What packages and versions are required to recognize this card with LMS 4.1?
Marvin Rhoads
The Sup2 requires 9.0 of the package file (dated 1/2/2013). You can download it here. (Click all Releases, 6.1.0, then choose the Nexus 7000 package.)
The readme is here. It mentions the N7K-C7009-FAB2 is supported (since 7.0) but nothing about the 7010-FAB-2 so you may still be out of luck on that one.
