01-17-2005 07:52 AM
I try installing ciscoworks 2000 (3rd Edition) on NT server. It runs the installation, but does appear in Start>Prog> Ciscoworks2000.
Inside the CiscoWorks2000 (in Programs) I can only * see the Add/delete Device
* Chnge Integration options
* Uninstallation
Thats all I see under Ciscoworks2000. I cannot see ciscoview or RME.
However IPM installs well and runs and is there in Programs.
Gaurav Prakash
01-17-2005 08:58 AM
Hello Gaurav,
Add/Delete device?
RME is a separate CD it does not come with
CD-ONE 3rd Edition
Can you tell me what version of RME is stated
on the CD you have?
IPM can exists on its own, it does not need to
be installed on the same machine as
CiscoWorks.
Can you bring up the WEB GUI for CiscoWorks, open
up a browser, enter the URL
http://
that would be the best test to see what is actually
installed, login with the default settings that is
listed in your packaging of CiscoWorks.
Hope that helps
01-18-2005 12:33 AM
http://
Will Ciscoview open from anywhere else. or ....
help
