CiscoWorks and ACS with SeureID
pkarolak76
I have problem with my CiscoWorks and ACS with SecureID. When I try to login to CiscoWorks by user which have token I can't do this. Of course if I do this by user which there is in ACS but password authentication is local (in ACS) I haven't any problems.
Do anybody know what I have to do in CiscoWorks?
My software:
Solaris, CiscoWorks LMS 2.6
David Stanford
Currently SecureID isn't supported.
It supports static passwords that are defined when you add devices to the DCR.
There is no Workaround
