Joe, if you see this, please help
I noticed yesterday I was getting some Java errors when opening different modules of Cisco Works, Campus Manager, RME.
I rebooted the server and everything seemd to be working fine. I tried to set up Notification Services after the reboot and it seemed to go without incident.
This morning Common Services shows
"DCA Server is down or inaccessable"
Campus Manager shows:
"Cannot connect to ANI Server since it is down"
Here is a clip from ani.log:
2007/12/28 08:00:08 Thread-76 ani ERROR DBConnection$ConnectionCreator: Failed to establish DB connectivity because: java.sql.SQLException: JZ006: Caught IOException: java.net.ConnectException: Connection refused: connect
2007/12/28 08:00:08 Discovery ani ERROR DiscoveryTimeBaseStat: Failed to enumerate Wbu table names because null
2007/12/28 08:00:08 Discovery ani DiscoveryTimeBaseStat: {NumDevices=31}{NumDiscovered=0}{NumDeleted=0}{DPH=14695}{OPH=0}
2007/12/28 08:00:08 Discovery ani DiscoveryTimeBaseImpl: completed: Discovery in 8578 ms
1198846847568 December 28, 2007 8:00:47 AM ES_SVRCWLMS__1198788044958(127) SVRCWLMS Error EDSSY0012: Cannot connect to EDS.
1198846910568 December 28, 2007 8:01:50 AM ES_SVRCWLMS__1198788044958(127) SVRCWLMS Error EDSSY0012: Cannot connect to EDS.
1198846973568 December 28, 2007 8:02:53 AM ES_SVRCWLMS__1198788044958(127) SVRCWLMS Error EDSSY0012: Cannot connect to EDS.
Reboot has not helped this morning.
I just found out we did some WIndows patches a couple of days ago.
