Ciscoworks CWLMS 2.5 Daemon Manager starting problem
ccoarqiva
Has anyone had problems after configuration of CWLMS with the Ciscoworks Daemon Manager not starting after a reboot of the system? My server is a Windows 2003 SP1 also it appears that the pdshow command also doesn't work i believe these two services use the same port number of 42340, can anyone help?
thanks in advance...
nhabib
Level 9
Level 9
What happens if you open a DOS shell and issue the command: net start crmdmgtd
paulmazzei
I have the exact same problem. My servers is Windows 2000 but the rest is the same. It was working before but after I came back from vacation this started happening.
I am running the Cisco Security Agent. I found that after the reboot if I stop the CSA Service, start the Ciscoworks Daemon Manager Service and then restart the CSA Service, everything works fine.
