ciscoworks daemon manager stuck at Stopping state
thongams2000
I am working on LMS 3.2 . Tried to stop the daemon service with " net stop crmdmgtd ". It stuck on stopping state since few hours now. I can still open the application. Need a suggestion to terminate the previous command and restart the
daemon service.
Vinod Arya
You should have dmgtd.exe process in Task Manager stuck.
Although you can kill it directly and then try the stop command once again before starting. But to be sure if any process in not stuck, best way would be to reboot the server once.
-Thanks Vinod **Rating Encourages contributors, and its really free. **
