02-17-2006 02:53 AM
Is there a device package for mds 9000 cisco switches which will allow ciscoworks to manage my mds 9120's. I'm pretty new to ciscoworks and just getting used to it but when I try to run ciscoview and select my 9120 device it says It doeesn't have the applicable devic package installed. I have looked at adding the device packages but can't see any which would support MDS 9000 range.
I am running ciscoworks ciscoview version 5.5
and this is my switch
Cisco Storage Area Networking Operating System (SAN-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (c) 2002-2005, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
BIOS: version 1.1.0
loader: version 1.2(2)
kickstart: version 2.1(2b)
system: version 2.1(2b)
BIOS compile time: 10/24/03
kickstart image file is: bootflash:/m9100-s1ek9-kickstart-mz.2.1.2b.bin
kickstart compile time: 8/30/2005 19:00:00 [09/18/2005 19:47:18]
system image file is: bootflash:/m9100-s1ek9-mz.2.1.2b.bin
system compile time: 8/30/2005 19:00:00 [09/18/2005 20:07:26]
Hardware
cisco MDS 9100 ("1/2 Gbps FC/Supervisor")
Intel(R) Pentium(R) III CPU - with 964000 kB of memory.
Processor Board ID JAB093400VV
bootflash: 500736 blocks (block size 512b)
slot0: 0 blocks (block size 512b)
mensa kernel uptime is 64 days 21 hours 42 minute(s) 37 second(s)
Last reset at 460859 usecs after Wed Dec 14 15:22:16 2005
Reason: Reset Requested by CLI command reload
System version: 2.1(2b)
Service:
Any help would be appreciated
Cheers
Gordon
02-17-2006 05:28 AM
The MDS switch line is not supported in CiscoView, as there is an equivalent management application that is embedded on the switches and works in tandem with the MDS Fabric Manager.
