Network Management
Don't miss this Cisco Catalyst 8000 offer
Labels
Hello. I'm trying to renew the ISE's certificate, but I'm using both admin and eap authentication, portal, and radius DTLS. In this case, I would like to know if renewing this certificate will reboot the ISE or if it will cause downtime. The certific...
CCC3 by Level 1
  • 13 Views
  • 0 replies
This started about last week; no changes have been made to any of the switches. We're a small business so not very many employees, but we're a TV station so we have multitudes of servers.Our Primary ISP is a 2gig by 2gig connection, same as our Secon...
MLIT by Level 1
  • 448 Views
  • 3 replies
I have a couple of Cisco Firepowers that I can access thru SSH or the FDM, but I can't console to them?-Software version: 7.0.5-72-Configured with primary and secondary-Base license-Not using FMCCan someone tell me how to get console access? Thank yo...
DSterling by Level 1
  • 224 Views
  • 7 replies
Resolved! EEM scripting help
I'm trying to have EEM script where I run the script manually and it display the output of the results in the session but for some reason I'm unable to do so. This is what I have so far(config)#event manager applet TestCommand(config-applet)# event n...
Sunny5 by Level 1
  • 427 Views
  • 16 replies
Dear all,I am configuring a network cfomposed of 4 VLANs with the following devices:- NetGate 6100 Firewall- A Cisco 2951 Router- Ciscon 2960 SwitchVLANs and DHCP were configured on the 2951 router.Note that NAT function is handled by the Firewall.Af...
Koffman by Level 1
  • 133 Views
  • 5 replies
Hello!I tested PPTP and L2TP VPN solutions, but considered another solution without the Cisco router involved.I've disabled all the virtual-access and vpdn stuff,sh run all | i vpdnreturns nothing, but the ports for PPTP and L2TP are still open and c...
mo01 by Level 1
  • 386 Views
  • 15 replies
