Hi Rizwan,
- Is it possible to display subnet based groups in RME as they are automatically created in CM? or can we display the subnet based groups by default created in CM in RME. ==> No.
- Is it possible to generate a report that shows that devices exist in each subnet based group or user defined group?
Check this for Group management :-
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_resource_manager_essentials/4.3/user/guide/groups.html
To the utmost you can create User defined group using using Variable IP.Address with operator range and define your network devices range accordingly.
3. When I run a Syslog Reload report from RME->Report Generator->Application (Syslog) and Report (Reload Report), CiscoWorks do generate a report but its not a accurate report. How to rectify this issue. ==> Kindly start new thread for this issue.
Gaganjeet
