02-21-2005 04:14 AM
Hi, there.
I have installed ciscoworks LMS 2.2 several minutes ago. The result for Self Test (Server Configuration-Diagnostics Menu) is very good (All subjects is "PASS").
But when I tried to setup Discovery Settings and SNMP Settings (Server Configuration-Setup Menu) I received the following messages. "The ANI Server is not responding. Verify that the ANI Server is up and running". Also when I clicked analyze ANI server, I got the following error. "AniWrapper>>analyze(SYSTEM) Server Named: ANIServer4.2-lms on port: 14004". Please help!!!
Best Regards,
Korea, Republic of.
From Alex Seo.
02-22-2005 10:55 AM
Are all the relevant latest CW patches and IDUs installed on the server?
02-22-2005 09:30 PM
my ciscoworks was running fine after i setup a few months ago.
recently, i also begin to experience the same error message when i start my ciscoworks.
what is happening ??
02-28-2005 02:22 PM
Hi all,
I'm experiencing the same problem and it started after I installed IDU 11 for CM v3.3. I did another installation last week with a different customer and there weren't any problems then. Is anyone else experiencing the same problem? I'm using a dual Xeon HP server with 2gigs of RAM so I don't think its related to the hardware resources.
02-28-2005 04:10 PM
Yes, of course.
Thanks for your concern. Have a nice day!
from Alex
03-01-2005 08:56 AM
I've solved my problem! I uninstalled CM 3.3 from the Ciscoworks server (leaving the other modules intact) and then re-installed it. This time, I installed IDU 5.0 then the bundle update followed by IDU 8.0 and finally IDU 11.0. It works like a charm now, hope this helps...
Cheers!
03-04-2005 02:22 PM
I have the same problem, everything looks fine (No failing processes detected) except for Device Support that appears ERROR RECEIVED. What did you do?.
Regards.
03-06-2005 06:27 AM
solved my problem after i uninstalled the netscout ngenius that i installed on the same machine as ciscoworks.
03-08-2005 11:31 AM
I did what you said and also I have reinstalled CW2K LMS 2.2 without Netscout nGenius.
Everything is still OK, but again About ANI Server--> Device Support Error Received and all appear as Unknown
Process Status ANI Server: Runnin with busy flag set
Something strange is when I create Self Test:
FAIL odbc.pl, is this related with my problem?
Can anybody hel me, please?
03-17-2005 07:09 AM
I have resolved my problem. I was installing CW2K under Windows 2000 Professional with Service Pack 3, as quick start said
I have uninstalled this OS and installed Windows 2000 Advanced Server3 with Service Pack 3. Therefore, I recommend install CW2K LMS 2.2 under this OS.
