Ciscoworks LMS 2.6 UDP port 6155
santipongv
What is CiscoWorks LMS 2.6 using UDP port 6155 for? It is being used by cwjawa.exe. I am not able to find it in the documentation. Thank you in advance.
Joe Clarke
This port is used by the LMS event system (specifically the ActiveMQ framework) for multicast discovery.
What is ActiveMQ framework? Is there a way to change the port number?
See http://activemq.apache.org/ for more on ActiveMQ. Briefly, this is one of many components used by LMS. IT provides message passing capabilities. There is no way to change this port in LMS.
