Ciscoworks LMS 3.0 and Ciscoworks Portal 1.0
agustinmar
Hello, I would like to know if Ciscoworks LMS 3.0 and Ciscoworks Portal 1.0 is the same thing, if it is not thus, what is the difference?
Thank you.
akemp
Level 5
Level 5
Ciscoworks LMS 3.0 is the suite of applications, Ciscoworks Portal is the new launch point application for all the other applications.
So in short no its not the same, Prtal is a subset of LMS 3.0.
