Ciscoworks LMS 4.0.1 and 3850 switch support
Anas Hijjawi
HI, I want to know if 3850 switch is supported in ciscoworks LMS 4.0.1, I added the devices, inventory collections successful but devices icon is  blue with question mark "?" and config sync fails always.
I tried to download the packages to install it but I couldn't find it.
thanks fo help
Thanks, Anas *--* Please rate the useful post,its free ;) *--*
Vinod Arya
3850 is supported on LMS 4.2.3. Check the supported list here :
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.2.3/device_support/table/lms423sdt.html
You need to upgrade either to LMS 4.2.3 or PI 1.3 onwards.
-Thanks
Vinod
**Rating Encourages contributors, and its really free. **
-Thanks Vinod **Rating Encourages contributors, and its really free. **
8 Replies 8
Vinod Arya
-Thanks
Vinod
mbilgrav
Level 3
Level 3
Works just great in LMS 4.2.4, latest patches
Anas Hijjawi
Thanks for the reply, but I don't have prime, I have ciscoworks LMS and last version is 4.0.1, I doupt I can upgrade to 4.2
I think I need a new license, am I correct?
Yes LMS 4.2 needs a new license. You can probably check once if your LMS 4.0.1 license allows you a free upgrade.
Many old LMS 4.0.1 were offered free Cisco Prime Infrastructure 1.x, which has LMS 4.2 available with.
You can check the contract covering your LMS 4.0 on Product upgrade tool :
http://tools.cisco.com/gct/Upgrade/jsp/productUpgrade.jsp
-Thanks
Vinod
FYI when I updated from 4.0 to 4.1 and later 4.2 i did not need any new license file.
I used the exact same file in a 4.2 install, that i used for the 4.0 install ...
so if you are allowed to download the 4.2 from CCO then you are entitled for this minor upgrade
Inline upgrades will work, but I am not aware of any free license migration on these higher releases. Each LMS instance has its own separate License as each one of them (LMS 4.0, LMS 4.1 and LMS 4.2) were released as major upgrades.
Its wonderful if it is working for you somehow.
We usually warn, so that people don't end up wasting time on this, when they dont intend to purchase.
Those who have a valid CCO ID are allowed to download a lot of softwares from CCO, which may need a valid license later.
Nothing against your setup, but this is as per Cisco's design guidelines I am aware of.
-Thanks
If you dont have a contract for CP LMS / PI - then you can not download it.
Same goes for WLC firmware, switch IOS etc
That is my experience with Cisco CCO. (my experience is very recent)
Besides that :
you can install - from scratch - a new LMS 4.2 and used the exact same license file as pr my 4.0 purchase.
I have done so many times to avoid upgrades with alot of bad data to migrate, or simply to start over on a corrupted installation.
So i agree with you that you do need a valid license file, and in this senarios he has a license file, and so if he can download the software-file then he is entitled, as you can not download cisco software with a contract assosiated with your CCO ID.
That is the Cisco way for normal enduser. I think it is somewhat more freely, when you are a Cisco employee.
syekhali
I agree with Vinod here. Upgrade to Cisco Prime LMS 4.2 from 4.0.x is a major upgrade and as per the licensing standards, you need to get a new/valid license to support Cisco Prime LMS 4.2.
Minor upgrades like upgrading to LMS 4.0.1 from LMS 4.0 which are minor upgrades do not require a License shuffle however major upgrades need one.
Like upgrading to LMS 4.0 from LMS 3.2.1 needed a new license.
Syed Khalid
