CiscoWorks LMS 4.0 remote migration
MathieuJM_2
We plan to update an old version of LMS 2.6 installed on Solaris 8.
The choices are to continue on a Solaris box or to migrate to a Windows server.
  • Is it possible to have some remote migration but using the same server as the old one where we plan to install Solaris 10 ?
  • Is it possible to do a remote migration from the Solaris server to a Windows server ?
yjdabear
> Yes. This should be not much different from remote migration between two servers, mostly hinging on taking good backup(s) with the wrapper script shipped with LMS 4.0.
> No, this apparenlty is still not possible: "Cross platform data migration is not supported."
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.0/install/guide/dmg.html#wp1208378
Thank you for your answer.
What could you recommand to migrate data from a Solaris installation to a Windows version ?
