09-19-2010 08:46 AM
Dear Helpers,
After succesful installation, I'm trying to login to the application from both client and server by web browser but the ciscoworks portal is not opening!
A video file attached showing:
- the problem
- pdshow -brief command
- services
Kindly help,
09-19-2010 08:53 AM
I dont see any attachments yet, but you might want to check these.
make sure you meet the server requirements:
Check the services startup type:
Automatic CiscoWorks Services: 1. CiscoWorks Daemon Manager 2. CWCS rsh/rcp service 3. CWCS syslog service 4. CWCS tftp service Manual services : 1. CiscoWorks Ani database engine 2. CiscoWorks RME NG database engine 3. CiscoWorks Tomcat Servlet Engine 4. CiscoWorks Web Server (Apache) 5. CWCS CMF database engine 6. DFM dfmEpm Database engine 7. DFM dfmFH database engine 8. DFM dfmInv database engine 9. IPM NG database Engine 10. ProcSysBus 11. OPsXMLRuntime
09-19-2010 11:50 AM
09-22-2010 02:33 AM
I installed the application in another server (Windows 2003) and it works well. But why it does not work with Windows 2008 as it's supported according to the documents?
