Ciscoworks offline update
Lasse Nylander
I have an LMS installed on an internal network. The network is not allowed to connect to internet.
Updating devicepackages etc. is rather cumbersome, manually downloading from cisco.com.
So I would like to know if anyone have an easy way around this, as I haven't been able to find much info on the subject anywhere else!
Lasse
Marvin Rhoads
Unfortunately in a scenario of no Internet connection to the LMS server, you will be constrained in the ease of applying updates. The best approach that I have used in such a situation is to script the commands for applying updates so that once you have manually downloaded them and put them in a predefined location that you can just execute the script to stop CiscoWorks, apply the updates and restart CiscoWorks.
On a Windows systems, that might look something like this (modified for you local environment variables):
net stop crmdmgtd
"C:\Program Files (x86)\CSCOpx\bin\PSUCli" -p cmf -install -src c:\psu_download\cmf -all
"C:\Program Files (x86)\CSCOpx\bin\PSUCli" -p cm -install -src c:\psu_download\cm -all
"C:\Program Files (x86)\CSCOpx\bin\PSUCli" -p rme -install -src c:\psu_download\rme -all
"C:\Program Files (x86)\CSCOpx\bin\PSUCli" -p cvw -install -src c:\psu_download\cvw -all
"C:\Program Files (x86)\CSCOpx\bin\PSUCli" -p dfm -install -src c:\psu_download\dfm -all
net start crmdmgtd
CiscoWorks will be available once again after the directory:
C:\Program Files (x86)\CSCOpx\objects\dmgt\ready
is empty.
Marvin Rhoads
net stop crmdmgtd
net start crmdmgtd
is empty.
Thank you, and sorry for my late reply .....
I have installed updates manually ie: /opt/CSCOpx/bin/perl update.pl, til now!
It should work just as well as the psucli or am I wrong ??
I just wish that a monthly released zip-file containing all new updates was available
Lasse
