Ciscoworks Product update
londint
We currently have Ciscoworks 2.2 and I have seen CDs with Ciscoworks Product Update with the following:
CiscoWorks Device Fault Manager (DFM) 2.0.3
? CiscoWorks Campus Manager 4.0.3
? CiscoWorks Resource Manager Essentials (RME) 4.0.3
? CiscoWorks Internetwork Performance Monitor (IPM) 2.6
? CiscoWorks CiscoView 6.1
? CiscoWorks Common Services 3.0.3
Does this mean I can only update the current version we have with these products? Can I do a new install with this new product?
akemp
Level 5
Level 5
You can upgrade or do a new install.
Where the sticky point is when you licence the new installation. There are two options for this: validate the new server against an old 2.2 server or validate against the original install CDs.
IMHO I would suggest you export your inventory to CSV file, do a new install on a new server (the 2.2 to 2.6 upgrade is fraught with some pretty nasty issues) then import.
