CiscoWorks restricted privileges
ntidcombe1
Beginner
Beginner
Can anyone tell me the simplest way to restrict Ciscoworks privileges. I do not want CW to have the ability to enter global config.
David Stanford
The easiest way in that situation is to integrate LMS with ACS. ACS can control the privileges that a user from CiscoWorks has when entering a device based on its device login credentials.
David Stanford
