04-06-2005 11:25 PM
We are using LMS 2.2 on solaris system, RME 3.5 and syslog message times are wrong.
this appeared after daylight saving changes.
is there a bug about that or a solution?
thanks
04-07-2005 12:37 AM
Time zones and time settings are matter of the OS on the server and the client (web browser client).
04-07-2005 12:47 AM
hi,
I ve solved my problem, I installed IDU10.
04-18-2005 06:13 AM
I got a bug for this issue: CSCsa27163. I think a fix is available, but don't remember in which RME IDU.
http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCsa27163&Submit=Search
I don't think it can be explained away by DST, although the symptom certainly seems to be triggered by DST. A 7200 router reloaded
at 12:19 EDT on 5/4/2004. RME Reloads Report reported the reload as 13:19 EDT.
This couldn't be explained by the Daylight Savings Time or Standard Time
difference, since then RME should have reported 11:19 instead.
As far as I can tell, every timestamp is correct, except in the Reload
Report (which got it in turn from DEV_RLD_HIST), where it's one hour
behind.
According to the DEV_RLD_HIST table at
http://ciscoworks:1741/dbreader/dbreader.html
82 2004-05-04 13:19:55.000 processor memory parity error at PC
0x604C210C,
address 0x0 2004-05-04 12:36:15.000
Reload time is "2004-05-04 13:19:55.000".
Updated time is "2004-05-04 12:36:15.000".
How could cw2k update its own database at 12:36 about a router's reload at
13:19, a time in the future?
This problem did not go away even after restarting cw2k daemons (twice) as TAC suggested.
