Ciscoworks RME - RICS001 error
Erik Molnar
Hello fellow forum members!
We have a problem with RME.
Inventory collection from a WS-C6513 switch is failing.
The error is,
RICS001 error - internal error
Info about the switch,
WS-C6513
ROM: System Bootstrap, Version 12.2(17r)SX7, RELEASE SOFTWARE (fc1)
And the corresponding ICServer log,
[ Fri Sep 02  10:40:58 CEST 2011 ],ERROR,[Thread-17],com.cisco.nm.rmeng.inventory.ics.server.InvDataProcessor,455,
java.lang.NullPointerException
    at com.cisco.nm.rmeng.inventory.ics.invdata.containment.ContainmentAGInvData.compare(ContainmentAGInvData.java:103)
    at com.cisco.nm.rmeng.inventory.ics.server.InvDataProcessor.processContainmentAG(InvDataProcessor.java:860)
    at com.cisco.nm.rmeng.inventory.ics.server.InvDataProcessor.processInvData(InvDataProcessor.java:329)
    at com.cisco.nm.rmeng.inventory.ics.core.CollectionController.run(CollectionController.java:915)
    at java.lang.Thread.run(Thread.java:595)
[ Fri Sep 02  10:40:58 CEST 2011 ],ERROR,[Thread-17],com.cisco.nm.rmeng.inventory.ics.core.CollectionController,927, Exception occured in process method while processing: 172.18.194.254 null
ICSException
    at com.cisco.nm.rmeng.inventory.ics.server.InvDataProcessor.processInvData(InvDataProcessor.java:470)
CSCsm97530  >> No you are not hitting this bug,
You are hitting the below bug :
CSCsx58694    IC via EntityMib failed due to Port (Port->Container->Module->Sensors)
My recommendation is to upgarde the cisco works to LMS 3.2  and this will take care of the issue..
here is the download link for LMS 3.2:
windows:
https://cisco.mediuscorp.com/market/networkers/productView.se.work?/nxt/rcrs/proieidentity/=17651
Solaris:
https://cisco.mediuscorp.com/market/networkers/productView.se.work?/nxt/rcrs/proieidentity/=17652
Note: you do not need a new license for LMS 3.2 , your Existing License should just work fine..
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
7 Replies 7
AFROJ AHMAD
Kindly Enable the Debugging for Inventory and send me the log files:
If LMS 3.2:
Go to RME > Admin > System Preferences > Application Log Level Settings under Application select ICServer
If it is LMS 4.0 : Go to
Admin >debug settings > Config and Image Management Debugging settings  >>
Change the Logging level to DEBUG  for all the Modules > Click Apply
Then ran a new Inventory Job  and send me the IC_server.log   (Location : NMSROOT\CSCopx\Log)
In the meantime try to Increase the SNMP Timeout and RETRY ,if you have not tried this yet:
LMS 3.2:
go to RME>Admin >system prefernece >RME device attributes :
LMS 4.0 :
Admin > Collection Settings > Inventory > Inventory/Config Timeout and Retry Settings
change the SNMP time out to 14 and SNMP RETRY to 3
and ran the job and see how it works !!!
Afroj
Hello!
I increased the timeot and retry attribute, but its not helping.
Here is the logfile.
Hi Erik,
Try deleting and Re-adding the device from RME and then run the Inventory job and see how it works..
If the job still fails then send me the new IC_server.log , along with the version of ciso works you are using ..
Afroj
Hello!
If i delete and re-add the device, the inventory job will run and will be OK for the first time, but the second inventory job will fail.
My Ciscoworks version is 3.1 and RME version is 4.2.0.
My first guess was this bug, CSCsm97530 but because my RME version 4.2.0 but now I am a bit puzzled.
windows:
Solaris:
Afroj
OK, i will try the upgrade.
Thanks for the help.
Hello!
The update worked, thank you.
